storage array port modify
Make changes to a target port record.
The storage array port modify
command lets the user change array target port parameters.
-name <text>
- Name-
Selects the array ports that match this parameter value. The storage array name is either generated by Data ONTAP or assigned by the user.
-wwnn <text>
- WWNN-
-wwpn <text>
- WWPN-
[-max-queue-depth <integer>]
- Target Port Queue Depth-
The target port queue depth for this target port.
[-utilization-policy {normal|defer}]
- Utilization Policy-
The policy used in automatically adjusting the queue depth of the target port based on its utilization.
This command changes the maximum queue depth for this target port to 32.
cluster1::> storage array port modify -name HITACHI_DF600F_1 -wwnn 50060e80004291c0 -wwpn 50060e80004291c0 -max-queue-depth 32
