vserver fpolicy policy event delete
Delete an event
The vserver fpolicy policy event delete
command deletes an FPolicy event.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the Vserver from which you want to delete an FPolicy event.
-event-name <Event name>
- Event-
This parameter specifies the name of the FPolicy event you want to delete.
The following example deletes an FPolicy event.
cluster1::> vserver fpolicy policy event delete -vserver vs1.example.com -event-name cifs_event
