vserver consistency-group snapshot restore
Restore a consistency group to a specified Snapshot copy
The vserver consistency-group snapshot restore command restores a Snapshot copy of a specified consistency group. This replaces the current working copy of the volume in the consistency group with the Snapshot copy that results in a loss of all changes made since the Snapshot copy was created.
-vserver <Vserver Name>- Vserver Name-
This specifies the Vserver that contains the consistency group on which the specified Snapshot copy to be restored is saved.
-consistency-group <text>- Consistency Group Name-
This parameter specifies the consistency group where a Snapshot copy is to be restored.
-snapshot <snapshot name>- Snapshot Copy Name-
This parameter specifies the name of the Snapshot copy that is to be restored.
[-parent-consistency-group <text>]- Parent Consistency Group Name-
This parameter specifies the parent consistency group where a Snapshot copy is to be restored.
The following example restores a Snapshot copy named snap1 on a consistency group named childCG on parent consistency group parentCG and is located on a Vserver named vs0.
cluster1::> vserver consistency-group snapshot restore -vserver vs0 -consistency-group childCG -parent-consistency-group parentCG -snapshot snap1
(vserver consistency-group snapshot restore)
[Job 100] Job succeeded: Success
