system services ndmp service modify
Modify NDMP service configuration
The system services ndmp service modify
command allows you to modify the NDMP service configurations for a node in the cluster. The following configuration can be modified:
NDMP Common Sessions
-node {<nodename>|local}
- Node (privilege: advanced)-
This specifies the node whose NDMP configuration is to be modified.
[-common-sessions <integer>]
- NDMP Common Sessions (privilege: advanced)-
This optional parameter specifies the number of extra common NDMP sessions supported, in addition to the number of backup and restore sessions supported for a platform. The default value is 4 for all platforms. The number of backup and restore sessions are platform dependent.
Increasing this parameter can make the storage system unresponsive.
The following example modifies the NDMP configuration on a node named node1. The configuration sets the NDMP Common Sessions to 16:
cluster1::> system services ndmp modify -node node1 -common-sessions 16
