vserver cifs group-policy show
Show group policy configuration
The vserver cifs group-policy show
command displays information about group policy configuration for CIFS-enabled Vserver. It displays all or a subset of the group policy configuration matching the criteria that you specify.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays group policy configuration only for the Vserver that you specify.
[-status {enabled|disabled}]
- Group Policy Status-
If you specify this parameter, the command displays group policy configuration only for the Vservers that match the status you specify.
The following example displays group policy configuration for all Vservers:
cluster1::> vserver cifs group-policy show Vserver GPO Status -------------- ---------- vs1 disabled
