ONTAP commands
vserver cifs group-policy show
Show group policy configuration
The vserver cifs group-policy show command displays information about group policy configuration for CIFS-enabled Vserver. It displays all or a subset of the group policy configuration matching the criteria that you specify.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays group policy configuration only for the Vserver that you specify.
[-status {enabled|disabled}] - Group Policy Status
If you specify this parameter, the command displays group policy configuration only for the Vservers that match the status you specify.
The following example displays group policy configuration for all Vservers:
cluster1::> vserver cifs group-policy show
Vserver         GPO Status
vs1              disabled
