system health alert modify
Modify system health alert
The system health alert modify
command suppresses alerts generated on the cluster and sets the acknowledgement state for an alert.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which you want to change the state.
-monitor <hm_type>
- Monitor-
Use this parameter to specify the monitor name on which you want to change the state.
-alert-id <text>
- Alert ID-
Use this parameter to specify the alert ID on which you want to change the state.
-alerting-resource <text>
- Alerting Resource-
Use this parameter to specify the alerting resource name on which you want to change the state.
[-acknowledge {true|false}]
- Acknowledge-
Use this parameter to set the acknowledgement state to true or false.
[-suppress {true|false}]
- Suppress-
Use this parameter to set the suppress state to true or false.
[-acknowledger <text>]
- Acknowledger-
Use this parameter to set the acknowledger as the filter for setting state.
[-suppressor <text>]
- Suppressor-
Use this parameter to set the suppressor as the filter for setting state.
This example modifies the alert field states on the cluster:
cluster1::> system health alert modify -node * -alert-id DualPathToDiskShelf_Alert -suppress true
