ONTAP commands
system health alert modify
Modify system health alert
The system health alert modify command suppresses alerts generated on the cluster and sets the acknowledgement state for an alert.
-node {<nodename>|local} - Node
Use this parameter to specify the node on which you want to change the state.
-monitor <hm_type> - Monitor
Use this parameter to specify the monitor name on which you want to change the state.
-alert-id <text> - Alert ID
Use this parameter to specify the alert ID on which you want to change the state.
-alerting-resource <text> - Alerting Resource
Use this parameter to specify the alerting resource name on which you want to change the state.
[-acknowledge {true|false}] - Acknowledge
Use this parameter to set the acknowledgement state to true or false.
[-suppress {true|false}] - Suppress
Use this parameter to set the suppress state to true or false.
[-acknowledger <text>] - Acknowledger
Use this parameter to set the acknowledger as the filter for setting state.
[-suppressor <text>] - Suppressor
Use this parameter to set the suppressor as the filter for setting state.
This example modifies the alert field states on the cluster:
cluster1::> system health alert modify -node * -alert-id DualPathToDiskShelf_Alert -suppress true
