vserver vscan connection-status show-all
Display Vscan servers connection status
The vserver vscan connection-status show-all
command displays connection status information of the external virus-scanning servers, or "Vscan servers". If you do not specify any parameters, the command displays the following information for all Vscan servers:
Vserver name
Node name
Vscan server
Connection status
Disconnect reason
You can specify the -fields
parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
Server type
Vscan server vendor
Vscan server version
Privileged user
Vscan server connected since
Vscan server disconnected since
Vserver LIF used for connection
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>]
- Server-
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-server-status <Status>]
- Server Status-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified status.
[-server-type <Server type>]
- Server Type-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
[-vendor <text>]
- Vscanner Vendor-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified vendor.
[-version <text>]
- Vscanner Version-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified version.
[-disconnect-reason <reason>]
- Server Disconnect Reason-
If you specify this parameter, the command displays information only about the Vscan servers that are disconnected because of the specified reason.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>]
- Time When Vscanner Was Disconnected-
If you specify this parameter, the command displays information only about the Vscan servers that have been disconnected since the specified time.
[-privileged-user <text>]
- Privileged User Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that are connected to clustered Data ONTAP using the specified privileged user.
[-connected-since <MM/DD/YYYY HH:MM:SS>]
- Time When Vscanner Was Connected-
If you specify this parameter, the command displays information only about the Vscan servers that have been connected since the specified time.
[-lif <IP Address>]
- Vserver LIF Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that have used the specified IP address for connecting to clustered Data ONTAP.
The following example displays connection-status information about all Vscan servers.
cluster1::> vserver vscan connection-status show-all Connection Vserver Node Server Status Disconnect Reason ----------- ----------------- --------------- -------------- ----------------- vs1 Cluster-01 1.1.1.1 disconnected remote-closed vs1 Cluster-01 2.2.2.2 connected - vs2 Cluster-01 3.3.3.3 disconnected no-data-lif vs2 Cluster-01 4.4.4.4 disconnected no-data-lif 4 entries were displayed.
The following example displays detailed connection-status information about all Vscan servers which are connected.
cluster1::> vserver vscan connection-status show-all -instance -server-status connected Node: Cluster-01 Vserver: vs1 Server: 2.2.2.2 Server Status: connected Server Type: primary Vscanner Vendor: XYZ Vscanner Version: 1.12.2 Server Disconnect Reason: - Time When Server Was Disconnected: - Privileged User Used for Connection: cifs\u2 Time When Server Was Connected: 6/3/2013 08:44:21 Vserver LIF Used for Connection: 10.238.41.223
