vserver vscan connection-status show-all
Display Vscan servers connection status
The vserver vscan connection-status show-all command displays connection status information of the external virus-scanning servers, or "Vscan servers". If you do not specify any parameters, the command displays the following information for all Vscan servers:
Vserver name
Node name
Vscan server
Connection status
Disconnect reason
You can specify the -fields parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
Server type
Vscan server vendor
Vscan server version
Privileged user
Vscan server connected since
Vscan server disconnected since
Vserver LIF used for connection
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>]- Server-
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-server-status <Status>]- Server Status-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified status.
[-server-type <Server type>]- Server Type-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
[-vendor <text>]- Vscanner Vendor-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified vendor.
[-version <text>]- Vscanner Version-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified version.
[-disconnect-reason <reason>]- Server Disconnect Reason-
If you specify this parameter, the command displays information only about the Vscan servers that are disconnected because of the specified reason.
[-disconnected-since <MM/DD/YYYY HH:MM:SS>]- Time When Vscanner Was Disconnected-
If you specify this parameter, the command displays information only about the Vscan servers that have been disconnected since the specified time.
[-privileged-user <text>]- Privileged User Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that are connected to ONTAP using the specified privileged user.
[-connected-since <MM/DD/YYYY HH:MM:SS>]- Time When Vscanner Was Connected-
If you specify this parameter, the command displays information only about the Vscan servers that have been connected since the specified time.
[-lif <IP Address>]- Vserver LIF Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that have used the specified IP address for connecting to ONTAP.
The following example displays connection-status information about all Vscan servers.
cluster1::> vserver vscan connection-status show-all
Connection
Vserver Node Server Status Disconnect Reason
vs1 Cluster-01 1.1.1.1 disconnected remote-closed
vs1 Cluster-01 2.2.2.2 connected -
vs2 Cluster-01 3.3.3.3 disconnected no-data-lif
vs2 Cluster-01 4.4.4.4 disconnected no-data-lif
4 entries were displayed.
The following example displays detailed connection-status information about all Vscan servers which are connected.
cluster1::> vserver vscan connection-status show-all -instance
-server-status connected
Node: Cluster-01
Vserver: vs1
Server: 2.2.2.2
Server Status: connected
Server Type: primary
Vscanner Vendor: XYZ
Vscanner Version: 1.12.2
Server Disconnect Reason: -
Time When Server Was Disconnected: -
Privileged User Used for Connection: cifs\u2
Time When Server Was Connected: 6/3/2013 08:44:21
Vserver LIF Used for Connection: 10.238.41.223
