metrocluster interconnect mirror show
Display MetroCluster interconnect mirror information
The metrocluster interconnect mirror show
command displays NVRAM mirror information for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Partner Name: This field specifies the name of the partner node.
Partner Type: This field specifies the type of the partner.
Mirror Admin Status: This field specifies the administrative status of the NVRAM mirror between partner nodes.
Mirror Oper Status: This field specifies the operational status of the NVRAM mirror between partner nodes.
Adapter: This field specifies the name of the interconnect adapter used for NVRAM mirroring.
Type: This field specifies the type of the interconnect adapter used for NVRAM mirroring.
Status: This field specifies the physical status of the interconnect adapter used for NVRAM mirroring.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
If this parameter is specified, mirror details of the specified node are displayed.
[-partner-type {HA|DR|AUX}]
- Partner Type-
If this parameter is specified, mirror details of the specified partner type are displayed.
[-adapter <text>]
- Adapter-
If this parameter is specified, mirror details of the specified adapter are displayed.
[-type <text>]
- Adapter Type-
If this parameter is specified, mirror details of the specified adapter type are displayed.
[-status <text>]
- Status-
If this parameter is specified, mirror details of the adapter with the specified status are displayed.
[-mirror-oper-status {unknown|online|offline}]
- Mirror Operational Status-
If this parameter is specified, only mirror details with the specified operational status are displayed.
[-partner-name <text>]
- Partner Name-
If this parameter is specified, mirror details of the specified partner are displayed.
[-mirror-admin-status {enabled|disabled}]
- Mirror Administrative Status-
If this parameter is specified, only mirror details with the specified administrative status are displayed.
The following example shows the output of the command during normal operation (neither cluster is in switchover state):
clusA::> metrocluster interconnect mirror show Mirror Mirror Partner Admin Oper Node Partner Name Type Status Status Adapter Type Status ---- ------------ ------- -------- ------- ------- ------ ------ clusA-01 clusA-02 HA enabled online cxgb3_0 iWARP Up cxgb3_0 iWARP Up clusB-01 DR enabled online fcvi_device_0 FC-VI Up fcvi_device_1 FC-VI Up clusA-02 clusA-01 HA enabled online cxgb3_0 iWARP Up cxgb3_0 iWARP Up clusB-02 DR enabled online fcvi_device_0 FC-VI Up fcvi_device_1 FC-VI Up
The following example shows the output of the command after MetroCluster switchover is performed:
clusA::> metrocluster interconnect mirror show Mirror Mirror Partner Admin Oper Node Partner Name Type Status Status Adapter Type Status ---- ------------ ------- -------- ------- ------- ------ ------ clusA-01 clusA-02 HA enabled online cxgb3_0 iWARP Up cxgb3_0 iWARP Up clusB-01 DR disabled offline fcvi_device_0 FC-VI Up fcvi_device_1 FC-VI Up clusA-02 clusA-01 HA enabled online cxgb3_0 iWARP Up cxgb3_0 iWARP Up clusB-02 DR disabled offline fcvi_device_0 FC-VI Up fcvi_device_1 FC-VI Up
