system controller ioxm show
Displays IOXM Device Health Status
The system controller ioxm show command displays the details of the IO expansion modules (IOXMs) that are connected to the nodes in a cluster. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about the IOXMs:
Node name
Display name
Is IOXM present?
Power status
Health monitor status
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information for all the IOXMs.
[-node {<nodename>|local}]- Node-
Selects the IOXM that is connected to the specified node.
[-chassis-config {c-i|c-c|c-b}]- Controller-IOXM or Controller-Controller or Controller-Blank-
Selects the IOXMs with the specified chassis configuration.
[-is-present {present|not-present}]- IOXM Presence-
Selects the IOXMs that are connected and detected (
present) or connected but not detected (not-present). [-power {good|bad}]- Power to IOXM-
Selects the IOXMs with the specified power state.
[-display-name <text>]- Display Name-
Selects the IOXMs with the specified display name.
[-unique-name <text>]- Unique Name-
Selects the IOXM with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]- Health Monitor Name-
Selects the IOXMs with the specified health monitor.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]- IOXM Health-
Selects the IOXMs with the specified health monitor status.
The example below displays the information of all the IOXMs that are connected to the nodes in a cluster.
cluster1::> system controller ioxm show Node Display Name Is-Present? Power Status ------------- ------------ ----------- --------- ------ node1 IOXM present good ok node2 IOXM present good ok
The example below displays detailed information of an IOXM that is connected to a node.
cluster1::> system controller ioxm show -instance -node node1
Node: node1
Controller-IOXM or Controller-Controller or Controller-Blank: c-i
IOXM Presence: present
Power to IOXM: good
Display Name: node1/IOXM
Unique Name: 8006459930
Health Monitor Name: controller
IOXM Health: ok
