security key-manager external azure check
Show detailed status of the enabled Azure Key Vault configurations
This command displays the Azure Key Vault (AKV) Key Management Service (KMS) status.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given node.
[-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given Vserver.
[-category <Categories for Cloud KMS status check>]
- Component (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given category.
Category Description -------- ----------- service_reachability Cloud KMS Reachability ekmip_server Embedded KMIP Server Reachability kms_wrapped_key_status Status of KMS Wrapped Keys On Cluster
[-status <Status Check>]
- Status (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status entries matching the given status.
OK FAILED UNKNOWN
[-detail <text>]
- Status Details (privilege: advanced)-
This field displays the detailed status message, if available.
The example below displays the status of all components of all AKV KMS configured on the node.
cluster-1::> security key-manager external azure check -node vsim1 Vserver: vs1 Node: vsim1 Category: service_reachability Status: OK Category: ekmip_server Status: OK Category: kms_wrapped_key_status Status: OK
