security key-manager external azure check
Show detailed status of the Azure Key Vault configurations
This command displays the Azure Key Vault (AKV) Key Management Service (KMS) status.
This command is only available to the Azure NetApp Files Cloud Volume Services. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given node.
[-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given Vserver.
[-category <Categories for KMS status check>]- Component (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status for the given category.
Category Description
service_reachability Cloud KMS Reachability
ekmip_server Embedded KMIP Server Reachability
kms_wrapped_key_status Status of KMS Wrapped Keys On Cluster
[-status <Status Check>]- Status (privilege: advanced)-
If this parameter is specified then the command displays only the AKV status entries matching the given status.
OK
FAILED
UNKNOWN
[-detail <text>]- Status Details (privilege: advanced)-
This field displays the detailed status message, if available.
The example below displays the status of all components of all AKV KMS configured on the node.
cluster-1::> security key-manager external azure check -node vsim1
Vserver: vs1
Node: vsim1
Category: service_reachability
Status: OK
Category: ekmip_server
Status: OK
Category: kms_wrapped_key_status
Status: OK
