snaplock log file archive
Archive Active Log Files in Log Volume
The snaplock log file archive
command archives the currently active log file by closing it and creating a new active log file. If base-name is not provided, the command archives all active log files associated with the Vserver. Otherwise, the command archives the active log file associated with the base-name provided.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver for which active log files need to be archived.
[-base-name {privileged-delete | system | legal-hold}]
- Base Name of Log File-
Specifies the log base-name, whose active log file needs to be archived. The base-name is the name of the source of log records. Valid base-names are
system
,privileged-delete
andlegal-hold
. Each base-name has its own directory in which log files containing log records generated by base-name are stored.
cluster1::> snaplock log archive -vserver vs1 [Job 48] Job succeeded: SnapLock log archived for Vserver "vs1".
