ONTAP commands
system chassis show
Display all the chassis in the cluster
The system chassis show command displays information about all the chassis in the cluster. By default, the command displays the following information about all the chassis in the cluster:
  • Chassis ID
  • Status
  • List of nodes in the chassis
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information about all the chassis in the cluster.
[-chassis-id <text>] - Chassis ID
Selects information about the specified chassis.
[-member-nodes {<nodename>|local}] - List of Nodes in the Chassis
Selects information about the chassis with the specified member node list.
[-num-nodes <integer>] - Number of Nodes in the Chassis
Selects information about the chassis with the specified number of nodes.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Status
Selects information about the chassis with the specified status.
The following example displays information about all the chassis in the cluster:
cluster1::> system chassis show
Chassis ID                 Status          List of Nodes
4591227214                 ok              node1,node2
4591227000                 ok              node1,node2
The following example displays detailed information about a specific chassis:
cluster1::> system chassis show -chassis-id 4591227214 -instance
                    Chassis ID: 4591227214
  List of Nodes in the Chassis: node1,node2
Number of Nodes in the Chassis: 2
                        Status: ok
