statistics aggregate show
Aggregate throughput and latency metrics
This command continuously displays performance data for aggregates at a regular interval. The command output displays data in the following columns:
Aggregate - aggregate name.
Node - node name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
- [-aggregate <text>]- Aggregate
Selects the aggregate for which you want to display performance data.
- [-node {<nodename>|local}]- Node
Selects the node for which you want to display performance data.
- [-sort-key <text>]- Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
- -interval <integer>- Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
- -iterations <integer>- Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
- -max <integer>- Maximum Number of Instances
Specifies maximum number of aggregates to display. The default setting is 25.
The following example displays aggregate statistics:
cluster1::> statistics aggregate show
cluster-1 : 12/31/1969 16:00:04
                                    *Total Read Write
            Aggregate          Node    Ops  Ops   Ops
aggr0_cluster_node2_0 cluster-node2      9    0     8
                aggr0 cluster-node1      6    0     5
 PDFs
PDFs
