statistics aggregate show
Aggregate throughput and latency metrics
This command continuously displays performance data for aggregates at a regular interval. The command output displays data in the following columns:
Aggregate - aggregate name.
Node - node name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
[-aggregate <text>]
- Aggregate-
Selects the aggregate for which you want to display performance data.
[-node {<nodename>|local}]
- Node-
Selects the node for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies maximum number of aggregates to display. The default setting is 25.
The following example displays aggregate statistics:
cluster1::> statistics aggregate show cluster-1 : 12/31/1969 16:00:04 *Total Read Write Aggregate Node Ops Ops Ops --------------------- ------------- ------ ---- ----- aggr0_cluster_node2_0 cluster-node2 9 0 8 aggr0 cluster-node1 6 0 5 [...]
