storage errors show
Display storage configuration errors.
The storage errors show command displays configuration errors with back end storage arrays.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-uid <text>]- UID-
Selects the disks that match this parameter value.
[-array-name <array name>]- Array Name-
Selects the disks that have the specified name for the storage array that is connected to the cluster.
[-node {<nodename>|local}]- Controller Name-
[-disk <disk path name>]- Disk-
[-serial-number <text>]- Serial Number-
[-error-id <integer>,…]- Error ID-
Selects the disks with error-id values that match this parameter value.
[-error-type {onepath|onedomain|control|foreign|toobig|toosmall|invalidblocksize|targetasymmap|deviceassymmap|failovermisconfig|unknown|netapp|fwdownrev|qualfail|diskfail|notallflashdisk}]- Error Type-
Selects the disks with error types values that match this parameter value.
The following example displays configuration errors seen in the system:
cluster1::> storage errors show Disk: vnv3070f20b:vnci9124s54:1-24.126L23 -------------------- vnci9124s54:1-24.126L23 (600a0b800019e999000036b24bac3983): This array LUN reports an invalid block size and is not usable. Only a block size of 512 is supported.
