volume encryption rekey show
Show status of a volume encryption rekey
The volume encryption rekey show
command displays information about volume encryption rekey in the cluster. By default, with no parameters, it only shows volume encryption rekey operations that have failed or are currently running. The command display output depends on the parameters passed. If -vserver
and -volume
are specified, the following information is displayed:
Vserver Name: The Vserver on which the volume is located.
Volume Name: The volume that is part of a completed or running volume move operation.
Start Time: The date and time when the volume encryption operation was started.
Status of Operation: The status of the operation.
Percentage Completed: The amount of work to encrypt the volume completed thus far in terms of percentage.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>]
- Volume Name-
This parameter specifies the name of the volume being encrypted.
[-start-time <MM/DD/YYYY HH:MM:SS>]
- Start Time-
If this parameter is specified, the command displays encryption operations that match the specified date and time in the cluster time zone when the volume move operation started.
[-status <text>]
- Status-
If this parameter is specified, the command displays encryption operations that match the specified status of the encryption operation.
The following example shows a sample output for this command:
cluster1::> volume encryption rekey show Vserver Volume Start Time Status ---------- ------------ --------------------- ----------------------- vs1 vol2 9/18/2017 17:51:41 Phase 2 of 2 (redirect scan) is in progress.
