vserver vscan scanner-pool modify
PDF of this doc site
Creating your file...
Modify a scanner pool
The vserver vscan scanner-pool modify
command modifies a Vscan scanner pool. Scanner pool is a set of attributes which are used to validate and manage connection between clustered Data ONTAP and external virus-scanning server, or "Vscan server". It also specifies other parameters which are used for connection management.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver on which you want to modify a scanner pool.
-scanner-pool <Scanner pool>
- Scanner Pool-
This parameter specifies the name of the scanner pool. Scanner pool name can be up to 256 characters long and is a string that can only contain any combination of ASCII-range alphanumeric characters (a-z, A-Z, 0-9), "_", "-" and ".".
[-hostnames <text>,…]
- List of Host Names of Allowed Vscan Servers-
This parameter specifies a list of host names or IP addresses of the Vscan servers which are allowed to connect to clustered Data ONTAP.
[-privileged-users <Privileged user>,…]
- List of Privileged Users-
This parameter specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name" and can be up to 256 characters long. Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
[-request-timeout <[<integer>h][<integer>m][<integer>s]>]
- Request Service Timeout (privilege: advanced)-
This parameter specifies the timeout value for a scan request. It specifies the time interval in which the node waits for a response from the Vscan server. If the timeout is reached, the node allows the file-operation if the applicable On-Access policy has scan-mandatory set to 'off'. If the policy has scan-mandatory set to 'on', then the node will retry the scan or disallow the file-operation depending on the remaining lifetime of the CIFS request. Valid values for this field are from 10s to 40s. However, if scan-mandatory is set to 'off', the effective value is limited to a maximum of 35s.
[-scan-queue-timeout <[<integer>h][<integer>m][<integer>s]>]
- Scan Queue Timeout (privilege: advanced)-
This parameter specifies the timeout value for a scan request in scan-engine's queue. The value for this field must be between 10s and 30s.
[-session-setup-timeout <[<integer>h][<integer>m][<integer>s]>]
- Session Setup Timeout (privilege: advanced)-
This parameter specifies the timeout value for a response for session-setup-message. The value for this field must be between 5s and 10s.
[-session-teardown-timeout <[<integer>h][<integer>m][<integer>s]>]
- Session Teardown Timeout (privilege: advanced)-
This parameter specifies the timeout value for a response for session-teardown-message, or for any message to be received for a session-id, after the underlying connection has been disconnected. The value for this field must be between 5s and 10s.
[-max-session-setup-retries <integer>]
- Max Number of Consecutive Session Setup Attempts (privilege: advanced)-
This parameter specifies the maximum number of consecutive session-setup attempts. The value for this field must be between 1 and 10.
The following example modifies a scanner pool.
Cluster1::> vserver vscan scanner-pool modify -vserver vs1 -scanner-pool SP -hostnames 2.2.2.2,vmwin204-29.fsct.nb -privileged-users cifs\u3 Cluster1::> vserver vscan scanner-pool show -vserver vs1 -scanner-pool SP Vserver: vs1 Scanner Pool: SP Applied Policy: idle Current Status: off Cluster on Which Policy Is Applied: - Scanner Pool Config Owner: vserver List of IPs of Allowed Vscan Servers: 2.2.2.2, 10.72.204.29 List of Host Names of Allowed Vscan Servers: 2.2.2.2, vmwin204-29.fsct.nb List of Privileged Users: cifs\u3
