vserver services web show
PDF of this doc site
Creating your file...
Display the current configuration of web services
This command displays the availability of the web services on Vservers. Only the services that are installed on every node in the cluster can be configured on Vservers whose type is not 'node'. Enabled services must include authorization configuration in the vserver services web access
command for the services to be externally available.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Identifies a Vserver for hosting a specific web service.
[-name <text>]
- Service Name-
Identifies the name of the web service.
[-type <vserver type>]
- Type of Vserver-
Identifies the type of Vserver on which the service is hosted.
[-version <text>]
- Version of Web Service-
Defines the version number of the service in the format of major.minor.patch.
[-description <text>]
- Description of Web Service-
Provides a short description of the web service.
[-long-description <text>]
- Long Description of Web Service-
Provides a long description of the web service.
[-requires <requirement>,…]
- Service Requirements-
Defines the list of requirements that must be met for the service to be successfully executed. Requirements are defined as a service name, a comparison operator (<⇒), and a version number.
[-default-roles <text>,…]
- Default Authorized Roles-
Defines the roles that are automatically granted access to the service in the vserver services web access show configuration.
[-enabled {true|false}]
- Enabled-
Defines the availability of a service on the Vserver. Disabled services are not accessible through the Vserver's network interfaces. This parameter's default value is dependent on the service. In general, services that provide commonly used features are enabled by default.
[-ssl-only {true|false}]
- SSL Only-
Defines the encryption enforcement policy for a service on the Vserver. Services for which this parameter is set to true support SSL only and cannot be used over unencrypted HTTP. The default for this value is 'false'.
This example displays the availability of the web services on the Vservers.
cluster1::vserver services web> show Vserver Type Service Name Description Enabled -------------- -------- ---------------- ----------------------------- ------- cluster1 admin cem OBSOLETE true cluster1 admin ontapi Remote Administrative API true cluster1 admin portal Data ONTAP Web Services true Portal n6070-8 node cem OBSOLETE true n6070-8 node ontapi Remote Administrative API true n6070-8 node portal Data ONTAP Web Services true Portal n6070-8 node spi Service Processor false Infrastructure n6070-8 node supdiag Support Diagnostics true Support n6070-9 node cem OBSOLETE true n6070-9 node ontapi Remote Administrative API true n6070-9 node portal Data ONTAP Web Services true Portal n6070-9 node spi Service Processor false Infrastructure n6070-9 node supdiag Support Diagnostics false Support 13 entries were displayed.
