The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock log create
PDF of this doc site
Creating your file...
Your file is ready
Create audit log configuration for a Vserver.
The `snaplock log create` command is used to create a SnapLock log configuration for the Vserver. A SnapLock log configuration consists of volume to store the log, the maximum size of the log file, and the default period of time for which the log file should be retained.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver for which the configuration needs to be created.
-volume <volume name>
- Log Volume Name-
Specifies the name of the volume that is used for logging. This must be a SnapLock Compliance volume.
[-max-log-size {<integer>[KB|MB|GB|TB|PB]}]
- Maximum Size of Log File-
Specifies the maximum size of the log file. Once a log file reaches this limit, it is archived and a new log file is created. This parameter is optional. The default value is
10MB
. [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Default Log Record Retention Period-
Specifies the default period of time a record (which is logged) is retained. This parameter is optional. The default value is
"6 months"
cluster1::> snaplock log create -volume vol1 -max-log-size 50MB -default-retention-period "1 year" -vserver vs1 [Job 47] Job succeeded: SnapLock log created for Vserver "vs1".
