metrocluster interconnect mirror multipath show
PDF of this doc site
Creating your file...
Display multipath information
The metrocluster interconnect mirror multipath show
command displays the NVRAM mirror multipath policy for the nodes configured in a MetroCluster.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Multipath Policy: This field specifies the multipath policy used for NVRAM mirroring.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
If this parameter is specified, mirror details of the specified node are displayed.
[-multipath-policy {no-mp|static-map|dynamic-map|round-robin}]
- Multipath Policy-
If this parameter is specified, nodes with the specidifed multipath policy are displayed.
The following example shows the output of the command:
clusA::> metrocluster interconnect mirror multipath show Node Multipath Policy --------------- ----------------- clusA-1 static-map clusA-2 static-map
