volume quota policy show
PDF of this doc site
Creating your file...
Display the quota policies
This command displays information about quota policies. The command displays the following information about all quota policies:
Vserver name
Policy name
When the policy was last modified
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information about the quota policies for the specified Vserver.
[-policy-name <text>]
- Policy Name-
If this optional parameter is specified, the command displays information about quota policies that match the specified name.
[-last-modified <MM/DD/YYYY HH:MM:SS>]
- Last Modified-
If this optional parameter is specified, the command displays information about quota policies with the last modified time that match the given time.
The following example displays information about all quota policies.
cluster1::> volume quota policy show Vserver Policy Name Last Modified --------------- -------------------- ---------------- vs0 quota_policy_vs0 10/16/2008 17:40:05 vs1 quota_policy_vs1 10/16/2008 17:47:45 vs2 quota_policy_vs2 10/16/2008 17:44:13 vs3 quota_policy_vs3 10/16/2008 17:44:13 4 entries were displayed.
