system timeout modify
Set the CLI inactivity timeout value
The system timeout modify command sets the timeout value for CLI sessions. If there is no CLI activity during the length of the timeout interval, the logged in user is logged out. The default value is 30 minutes. To prevent CLI sessions from timing out, specify a value of 0 (zero).
[-timeout <integer>] - Timeout (in minutes)
Use this parameter to specify the timeout value, in minutes.
The following example shows how to modify the timeout value for CLI sessions to be 10 minutes:
cluster1::> system timeout modify -timeout 10
The following example shows how to prevent CLI sessions from timing out:
cluster1::> system timeout modify -timeout 0
