ONTAP commands
vserver cifs cache settings show
Display CIFS Cache Configuration
The vserver cifs cache settings show command displays information about the Windows users cache configuration of the specified Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
Use this parameter to display detailed information about the Windows users cache configuration settings.
[-vserver <vserver name>] - Vserver (privilege: advanced)
Use this parameter to display information about the Windows users cache configuration settings for the Vserver you specify.
[-is-enabled {true|false}] - Is Cache Enabled? (privilege: advanced)
Use this parameter to display information only about the Windows users cache configuration settings that have the specified cache enabled setting. Value true displays only the entries that have cache enabled and value false displays only the entries that have cache disabled.
[-is-negative-cache-enabled {true|false}] - Is Negative Cache Enabled? (privilege: advanced)
Use this parameter to display information only about the Windows users cache configuration settings that have the specified negative cache enabled setting. Value true displays only the entries that have negative cache enabled and value false displays only the entries that have negative cache disabled.
[-ttl <[<integer>h][<integer>m][<integer>s]>] - Time to Live (privilege: advanced)
Use this parameter to display information only about the Windows users cache configuration settings that have the specified Time to Live.
[-negative-ttl <[<integer>h][<integer>m][<integer>s]>] - Negative Time to Live (privilege: advanced)
Use this parameter to display information only about the Windows users cache configuration settings that have the specified negative Time to Live.
[-is-propagation-enabled {true|false}] - Is Propagation Enabled? (privilege: advanced)
Use this parameter to display information only about the Windows users cache configuration settings that have the specified propagation enabled setting. Value true displays only the entries that have the propagation of cached entries to sid-to-name cache enabled and value false displays only the entries that have the propagation of cached entries to sid-to-name cache disabled.
The following example shows how to display the Windows users cache configuration settings for all the Vservers:
cluster1::> vserver cifs cache settings show
The following example shows how to display the Windows users cache configuration settings for Vserver vs0:
cluster1::> vserver cifs cache settings show -vserver vs0
The following example shows how to display the Windows users cache configuration settings that have cache disabled:
cluster1::> vserver cifs cache settings show -is-enabled false
