vserver cifs symlink modify
PDF of this doc site
Creating your file...
Modify a symlink path mapping
The vserver cifs symlink modify
command modifies the CIFS share name, CIFS path, CIFS server name, or locality of a symbolic link mapping. It can also be used to modify the value of -home-directory
field.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the symbolic link mapping is located.
-unix-path <text>
- UNIX Path-
This parameter specifies the UNIX (NFS) path of the mapping that you want to modify.
It must begin and end with a forward slash (/). [-share-name <Share>]
- CIFS Share-
This parameter specifies a new CIFS share name for the mapping.
[-cifs-path <TextNoCase>]
- CIFS Path-
This parameter specifies a new CIFS path for the mapping. Note that this value is specified by using a UNIX-style path.
It must begin and end with a forward slash (/). [-cifs-server <TextNoCase>]
- Remote NetBIOS Server Name-
This parameter specifies a new CIFS server DNS name, IP address, or NetBIOS name for the mapping.
[-locality {local|widelink}]
- Local or Wide Symlink-
This parameter specifies a new locality for the mapping. A local symbolic link maps to the local CIFS share. A free symbolic link can map anywhere on the local server. A wide symbolic link maps to any CIFS share on the network. The default setting is
local
. The free link option is obsolete. [-home-directory {true|false}]
- Home Directory-
This parameter specifies whether the new target share is a home directory.
This field must be set to true when the target share is a Home Directory for correct processing.
The following example modifies the symbolic link mapping to a UNIX path /example/ on a Vserver named vs1. The mapping is modified to use the CIFS path /mycompany/example/.
cluster1::> vserver cifs symlink modify -vserver vs1 -unix-path /example/ -cifs-path "/mycompany/example/"
The following example modifies the symbolic link mapping to a UNIX path /example/ on a Vserver named vs1. The mapping is modified to use the CIFS share name EXAMPLE_SHARE, the CIFS path /mycompany/example/, on the CIFS server cifs.example.com, and to be a wide link.
cluster1::> vserver cifs symlink modify -vserver vs1 -unix-path /example/ -share-name EXAMPLE_SHARE -cifs-path "/mycompany/example/" -cifs-server cifs.example.com -locality widelink
