storage aggregate show-auto-provision-progress
Display aggregate auto provision status
The storage aggregate show-auto-provision-progress
command displays the status of the most recent auto provision operation. The command output displays the progress for all the aggregates included in the provisioning operation. The command displays the following information about each aggregate:
Aggregate
Current Usable Size
Target Usable Size
Provisioning Progress
The following example displays the information about all aggregates that are provisioned during the aggregate auto provision operation:
cluster1::> aggr auto-provision Node New Data Aggregate Usable Size ------------------ ---------------------------- ------------ node1 node1_SSD_1 23.65GB node2 node2_SSD_1 23.65GB ------------------ ---------------------------- ------------ Total: 2 new data aggregates 47.30GB Do you want to create recommended aggregates? {y|n}: y Info: Aggregate auto provision has started. Use the "storage aggregate show-auto-provision-progress" command to track the progress. cluster1::> storage aggregate show-auto-provision-progress Current Target Aggregate Usable Size Usable Size Provisioning Progress ---------------------------- ------------ ------------ ----------------------- node1_SSD_1 0B 23.65GB Creating node2_SSD_1 0B 23.65GB Creating cluster1::> storage aggregate show-auto-provision-progress Current Target Aggregate Usable Size Usable Size Provisioning Progress ---------------------------- ------------ ------------ ----------------------- node1_SSD_1 23.65GB 23.65GB Completed node2_SSD_1 23.65GB 23.65GB Completed
