system node autosupport invoke-splog
PDF of this doc site
Creating your file...
Generate and send an AutoSupport message with collected service-processor log files
The system node autosupport invoke-splog
command sends an AutoSupport message with the Service Processor log files from a specified node in the cluster.
-remote-node {<nodename>|local}
- Node-
Use this parameter to specify the node from which Service Processor log files are to be collected.
[-log-sequence <integer>]
- Log File Sequence Number-
Use this parameter to specify the sequence number of the Service Processor log files to be collected. If this parameter is omitted, the latest Service Procesor log files are collected.
[-uri <text>]
- Alternate Destination for This AutoSupport-
Use this parameter to send the AutoSupport message to an alternate destination. Only "file," "http," and "https" protocols are supported. If this parameter is omitted, the message is sent to the all of the recipients defined by the system node autosupport modify command.
[-force <true>]
- Generate and Send Even if Disabled-
Use this parameter to generate and send the AutoSupport message even if AutoSupport is disabled on the node.
Use this command to invoke an AutoSupport message to include the Service Processor log files collected from node cluster1-02.
cluster1::> system node autosupport invoke-splog -remote-node cluster1-02 [Job 777] Job succeeded: Log files from the service processor have been transferred to "/mroot/etc/log/sp/ondemand" on node cluster1-01, and AutoSupport message has been triggered. cluster1::>
