volume rehost
Rehost a volume from one Vserver into another Vserver
The volume rehost command rehosts a volume from source Vserver onto destination Vserver. The volume name must be unique among the other volumes on the destination Vserver.
-vserver <vserver name> - Source Vserver name
This specifies the Vserver on which the volume is located.
-volume <volume name> - Target volume name
This specifies the volume that is to be rehosted.
-destination-vserver <vserver name> - Destination Vserver name
This specifies the destination Vserver where the volume must be located post rehost operation.
{ [-force-unmap-luns {true|false}] - Unmap LUNs in volume
This specifies whether the rehost operation should unmap LUNs present on volume. The default setting is false (the rehost operation shall not unmap LUNs). When set to true, the command will unmap all mapped LUNs on the volume.
