volume rehost
Rehost a volume from one Vserver into another Vserver
The volume rehost
command rehosts a volume from source Vserver onto destination Vserver. The volume name must be unique among the other volumes on the destination Vserver.
-vserver <vserver name>
- Source Vserver name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Target volume name-
This specifies the volume that is to be rehosted.
-destination-vserver <vserver name>
- Destination Vserver name-
This specifies the destination Vserver where the volume must be located post rehost operation.
[-force-unmap-luns {true|false}]
- Unmap LUNs in volume -
This specifies whether the rehost operation should unmap LUNs present on volume. The default setting is
false
(the rehost operation shall not unmap LUNs). When set to true, the command will unmap all mapped LUNs on the volume. - |
[-auto-remap-luns {true|false}]
- Automatic Remap of LUNs } -
This specifies whether the rehost operation should perform LUN mapping operation at the destination Vserver for the LUNs mapped on the volume at the source Vserver. The default setting is
false
(the rehost operation shall not map LUNs at the destination Vserver). When set to true, at the destination Vserver the command will create initiators groups along with the initiators (if present) with same name as that of source Vserver. Then the LUNs on the volume are mapped to initiator groups at the destination Vserver as mapped in source Vserver.
The following example rehosts a volume named vol3 on Vserver named vs1 to a destination Vserver named vs2:
cluster::> volume rehost -vserver vs1 -volume vol3 -destination-vserver vs2
