cluster add-node
PDF of this doc site
Creating your file...
Your file is ready
Expand the cluster by discovering and adding new nodes
The cluster add-node
command discovers and adds new nodes to the cluster. When the -node-count
parameter is specified, the command attempts to add that many nodes to the cluster. The -node-ip
parameter can be specified to directly add a node. The -cluster-ips
parameter can be specified to directly add one or more nodes in parallel. Only one of the -node-count
, -node-ip
and -cluster-ips
parameters can be provided. The system node show-discovered command displays all the nodes discovered on the local network.
The |
