network subnet show
Display subnet information
Display subnet information.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ipspace <IPspace>]
- IPspace Name-
Selects the subnets that match the given IPspace name.
[-subnet-name <subnet name>]
- Subnet Name-
Selects the subnets that match the given subnet name.
[-broadcast-domain <Broadcast Domain>]
- Broadcast Domain-
Selects the subnets that match the given broadcast domain name.
[-subnet <IP Address/Mask>]
- Layer 3 Subnet-
Selects the subnets that match the given address and mask.
[-gateway <IP Address>]
- Gateway-
Selects the subnets that match the given gateway address.
[-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}]
- IP Addresses or IP Address Ranges-
Selects the subnets that match the given IP range.
[-total-count <integer>]
- Total Address Count-
Selects the subnets that match the given total address count.
[-used-count <integer>]
- Used Address Count-
Selects the subnets that match the given number of addresses allocated.
[-available-count <integer>]
- Available Address Count-
Selects the subnets that match the given number of addresses available.
The following example displays general information about the subnets.
cluster1::> network subnet show IPspace: Default Subnet Broadcast Avail/ Name Subnet Domain Gateway Total Ranges --------- ---------------- --------- --------------- --------- --------------- s4 192.168.4.0/24 bd4 192.168.4.1 5/5 192.168.5.6-192.168.5.10 s6 192.168.6.0/24 bd4 192.168.6.1 5/5 192.168.6.6-192.168.6.10 IPspace: ips1 Subnet Broadcast Avail/ Name Subnet Domain Gateway Total Ranges --------- ---------------- --------- --------------- --------- --------------- s10 192.168.6.0/24 bd10 192.168.6.1 0/0 - 3 entries were displayed.
