network subnet show
Display subnet information
Display subnet information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ipspace <IPspace>]- IPspace Name-
Selects the subnets that match the given IPspace name.
[-subnet-name <subnet name>]- Subnet Name-
Selects the subnets that match the given subnet name.
[-broadcast-domain <broadcast domain name>]- Broadcast Domain-
Selects the subnets that match the given broadcast domain name.
[-subnet <IP Address/Mask>]- Layer 3 Subnet-
Selects the subnets that match the given address and mask.
[-gateway <IP Address>]- Gateway-
Selects the subnets that match the given gateway address.
[-ip-ranges {<ipaddr>|<ipaddr>-<ipaddr>}]- IP Addresses or IP Address Ranges-
Selects the subnets that match the given IP range.
[-total-count <integer>]- Total Address Count-
Selects the subnets that match the given total address count.
[-used-count <integer>]- Used Address Count-
Selects the subnets that match the given number of addresses allocated.
[-available-count <integer>]- Available Address Count-
Selects the subnets that match the given number of addresses available.
The following example displays general information about the subnets.
cluster1::> network subnet show
IPspace: Default
Subnet Broadcast Avail/
Name Subnet Domain Gateway Total Ranges
s4 192.168.4.0/24 bd4 192.168.4.1 5/5 192.168.5.6-192.168.5.10
s6 192.168.6.0/24 bd4 192.168.6.1 5/5 192.168.6.6-192.168.6.10
IPspace: ips1
s10 192.168.6.0/24 bd10 192.168.6.1 0/0 -
3 entries were displayed.
