system health alert modify
PDF of this doc site
Creating your file...
Modify system health alert
The system health alert modify
command suppresses alerts generated on the cluster and sets the acknowledgement state for an alert.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which you want to change the state.
-monitor <hm_type>
- Monitor-
Use this parameter to specify the monitor name on which you want to change the state.
-alert-id <text>
- Alert ID-
Use this parameter to specify the alert ID on which you want to change the state.
-alerting-resource <text>
- Alerting Resource-
Use this parameter to specify the alerting resource name on which you want to change the state.
[-acknowledge {true|false}]
- Acknowledge-
Use this parameter to set the acknowledgement state to true or false.
[-suppress {true|false}]
- Suppress-
Use this parameter to set the suppress state to true or false.
[-acknowledger <text>]
- Acknowledger-
Use this parameter to set the acknowledger as the filter for setting state.
[-suppressor <text>]
- Suppressor-
Use this parameter to set the suppressor as the filter for setting state.
This example modifies the alert field states on the cluster:
cluster1::> system health alert modify -node * -alert-id DualPathToDiskShelf_Alert -suppress true
