system node autosupport history show-upload-details
Display upload details of recent AutoSupport messages
The system node autosupport history show-upload-details
command displays upload details of the 50 most recent AutoSupport messages sent by nodes in the cluster. By default, it displays the following information:
AutoSupport Sequence Number
Destination
Compressed Size
Percentage Complete
Rate of upload
Time Remaining
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Use this parameter to display the following detailed information about all entries:
Destination
Compressed Size
Percentage Complete
Rate of Upload
Time Remaining
[-node {<nodename>|local}]
- Node-
Use this parameter to display details of AutoSupport messages sent from the node you specify.
[-seq-num <Sequence Number>]
- AutoSupport Sequence Number-
Use this parameter to display details of AutoSupport messages with the sequence number you specify. Sequence numbers are unique to a node. Use this parameter with the
-node
parameter to display information about an individual message. [-destination {smtp|http|noteto|retransmit}]
- Destination for this AutoSupport-
Use this parameter to display details of AutoSupport messages that were sent to the destination type you specify.
[-size {<integer>[KB|MB|GB|TB|PB]}]
- Autosupport Compressed Size-
Use this parameter to display details of AutoSupport messages of the compressed size you specify.
[-percent-complete <integer>]
- Percent Complete-
Use this parameter to display the percentage completed for any active (incomplete) AutoSupport message.
[-upload-rate {<integer>[Bps|KBps|MBps|GBps]|unlimited}]
- Rate of Upload-
Use this parameter to display the rate in bytes per second that upload is using currently, otherwise zero when not active.
[-time-remaining <[<integer>h][<integer>m][<integer>s]>]
- Time remaining for Upload-
Use this parameter to display the estimated time for the transmission of the AutoSupport message to complete.
The following example shows the first three results output by the history show-upload-details command. Note that "q" was pressed at the prompt.
cluster1::> system node autosupport history show-upload-details -node node1 Seq Percent Time Node Num Destination Size Complete Rate Remaining ------------ ----- ----------- --------- ---------- ----------- -------- node1 13 smtp 755.9KB 100 142.88KBps 0s http 755.8KB 80 125.97KBps 10s noteto - - - - 12 smtp - - - - http 316.4KB 100 158.22KBps 0s noteto 201B 100 201Bps 0s 11 smtp - - - - http 626.1MB 100 649.56KBps 0s noteto - - - - Press <space> to page down, <return>> for next line, or 'q' to quit... q 9 entries were displayed.
