vserver nvme show-interface
Display the NVMe over Fabrics LIF configuration
The vserver nvme show-interface
command displays the currently available interfaces to the NVMe protocol.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the NVMe interfaces that match the Vserver that you specify.
[-lif <lif-name>]
- Logical Interface-
Use this parameter to display the NVMe interfaces that match the LIF that you specify.
[-vserver-uuid <UUID>]
- Vserver UUID-
Use this parameter to display the NVMe interfaces that match the Vserver UUID that you specify.
[-home-node <nodename>]
- Home Node-
Use this parameter to display the NVMe interfaces that match the home node that you specify.
[-home-port {<netport>|<ifgrp>}]
- Home Port-
Use this parameter to display the NVMe interfaces that match the home port that you specify.
[-status-admin {up|down}]
- Status Admin-
Use this parameter to display the NVMe interfaces that match the administrative status that you specify.
[-physical-protocol <fibre-channel>]
- Physical Protocol-
Use this parameter to display the NVMe interfaces that match the physical protocol that you specify.
[-transport-protocol {fc-nvme|rdma-nvme}]
- Transport Protocol-
Use this parameter to display the NVMe interfaces that match the transport protocol that you specify.
[-transport-address <text>]
- Transport Address-
Use this parameter to display the NVMe interfaces that match the transport address that you specify.
[-comment <text>]
- Comment-
Use this parameter to display the NVMe interfaces that match the textual comment that you specify.
[-fc-wwnn <FC WWN>]
- FC WWNN-
Use this parameter to display the NVMe interfaces that match the FC WWNN that you specify.
[-fc-wwpn <FC WWN>]
- FC WWPN-
Use this parameter to display the NVMe interfaces that match the FC WWPN that you specify.
[-lif-id <integer>]
- LIF ID-
Use this parameter to display the NVMe interfaces that match the LIF ID that you specify.
[-lif-uuid <UUID>]
- LIF UUID-
Use this parameter to display the NVMe interfaces that match the LIF UUID that you specify.
cluster1::*> vserver nvme show-interface Vserver Logical Interface Home Node:Port Transport Protocols ------- -------------------- ------------------ ----------------------------- vs_1 nvme1 node1:1a fc-nvme Transport Address: nn-0x2000005056b45113:pn-0x2001005056b45113
