storage tape load-balance show
PDF of this doc site
Creating your file...
Displays the tape load balance configuration
The storage tape load-balance show
command displays tape load balance settings for each node in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects information about tape load balancing for the specified node.
[-is-enabled {true|false}]
- Is Tape Load Balance Enabled-
Selects information about load balance configuration as specified by enabled or disabled setting.
The following example shows the load balance setting for each node in the cluster:
cluster1::> storage tape load-balance show Node Enabled --------------------------- --------- node1 false node2 false 2 entries were displayed.
