volume efficiency policy create
PDF of this doc site
Creating your file...
Create an efficiency policy
The volume efficiency policy create
creates an efficiency policy.
-vserver <vserver name>
- Vserver-
Specifies the Vserver on which the volume is located.
-policy <text>
- Efficiency Policy Name-
This specifies the policy name.
[-type <Efficiency policy type>]
- Policy Type-
This specifies the policy type. The policy type defines when the volume using this policy will start processing a changelog. There are two possible values:
threshold
means changelog processing occurs when the changelog reaches a certain percentage. -
scheduled
means changelog processing will be triggered by time.
The default value is
scheduled
[-schedule <text>]
- Job Schedule Name-
This specifies the job schedule. Use
job schedule
commands to manage job schedules. Only cron job schedules are supported. [-duration <text>]
- Duration-
This specifies the duration that an efficiency operation can run (in hours). The possible values are "-" or a number between 1 and 999 inclusive. Default value is "-", which means no duration.
[-start-threshold-percent <percent>]
- Threshold Percentage-
The percentage at which the changelog will be processed. The percentage is checked on an hourly basis. The default value is 20. Valid only if
-type
parameter is set asthreshold
. [-qos-policy <Efficiency QoS policy>]
- QoS Policy-
This specifies how the efficiency operations are throttled. This option can be configured to be
background
orbest-effort
. Default value isbest-effort
. Ifbackground
is specified, the efficiency operations are run with minimum or no impact on the data serving client operations. Ifbest-effort
is specified, the efficiency operations might have some impact on the data serving client operations. [-enabled {true|false}]
- Enabled-
This specifies whether the policy is enabled or not. The policy is enabled by default.
[-comment <text>]
- Comment-
User specified comment.
The following example creates an efficiency policy.
cluster1::> volume efficiency policy create -vserver vs1 -policy policy1 -schedule daily -duration 100
