The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver remove-aggregates
PDF of this doc site
Creating your file...
Your file is ready
Remove aggregates from the Vserver
The vserver remove-aggregates
command removes aggregates from the Vserver.
-vserver <vserver>
- Vserver-
Specifies the Vserver from which aggregates have to be removed.
-aggregates <aggregate name>,…
- List of Aggregates to Be Removed-
Specifies the list of aggregates to remove from the Vserver.
The following example illustrates how to remove aggregates aggr1
and aggr2
from a Vserver named vs.example.com
cluster1::> vserver remove-aggregates -vserver vs.example.com -aggregates aggr1,aggr2
