storage aggregate resynchronization options show
PDF of this doc site
Creating your file...
Display node specific aggregate resynchronization options
The storage aggregate resynchronization options show
command displays all the options that govern the resynchronization of aggregates on a given cluster node. If no parameters are specified, the command displays the following information about all nodes:
Node for which the information is being displayed
Maximum number of concurrent resynchronizing aggregates allowed
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If this parameter is specified, the command displays resynchronization options only for the specified node.
[-max-concurrent-resync <integer>]
- Maximum Concurrent Resynchronizing Aggregates-
If this parameter is specified, the command displays only the resynchronization option that matches the specified value.
The following example displays the maximum number of concurrent resyncs allowed for each node in the cluster:
cluster1::> storage aggregate resynchronization options show Node Maximum Concurrent Resynchronizing Aggregates ------------- --------------------------------------------- cluster1-01 15 cluster1-02 4 2 entries were displayed.
The following example displays the maximum number of concurrent resyncs allowed for a specified node:
cluster1::> storage aggregate resynchronization options show -node node1 Node Maximum Concurrent Resynchronizing Aggregates ------------- --------------------------------------------- cluster1-01 15
The following example displays all the nodes that allow more than five concurrent resync operations:
cluster1::> storage aggregate resynchronization options show -max-concurrent-resyncs >5 Node Maximum Concurrent Resynchronizing Aggregates ------------- --------------------------------------------- cluster1-01 15
