The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage automated-working-set-analyzer start
PDF of this doc site
Creating your file...
Your file is ready
Command to start Automated Working Set Analyzer on node or aggregate
The automated-working-set-analyzer start command enables the Automated Workload Analyzer that is capable of doing the following:
Flash Pool modeling for an aggregate
Flash Cache modeling for a node - can not specify an aggregate.
Working set size estimation
Workload monitoring
-node <nodename>
- Node Name (privilege: advanced)-
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}]
- Flash Cache Node-wide Modeling (privilege: advanced)-
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate <aggregate name>]
- Aggregate (privilege: advanced)-
This parameter indicates the aggregate name that the AWA instance runs on.
[-working-set-size {true|false}]
- Working Set Size (privilege: advanced)-
This parameter indicates whether the AWA instance is configured to find the working set size.
cluster1::> storage automated-working-set-analyzer start -node vsim1 -aggregate aggr0
