security key-manager prepare-to-downgrade
(DEPRECATED)-Disables onboard keymanagement features for unsupported versions
This command is deprecated and might be removed in a future release. |
The security key-manager prepare-to-downgrade command disables the onboard key management features that are not supported in releases prior to ONTAP 9.1.0. The features that are disabled are onboard key management support for Metrocluster configurations and Volume Encryption (VE).
The following example disables the onboard key management support for Metrocluster configurations and Volume Encryption (VE):
cluster1::*> security key-manager prepare-to-downgrade
