storage aggregate relocation show
PDF of this doc site
Creating your file...
Display relocation status of an aggregate
The storage aggregate relocation show
command displays status of aggregates which were relocated in the last instance of relocation operation.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command only displays the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all entries. [-node {<nodename>|local}]
- Node-
Selects aggregates from the specified source node.
[-aggregate <text>]
- Aggregate Name-
Selects the aggregates that match this parameter value.
[-relocation-status <text>]
- Aggregates Relocation Status-
Selects the aggregates whose relocation status matches this parameter value.
[-destination <text>]
- Destination for Relocation-
Selects the aggregates that are designated for relocation on the specified destination node.
The following example displays the relocation status of aggregates on all nodes in the cluster:
cluster1::> storage aggregate relocation show Source Aggregate Destination Relocation Status -------------- ---------- ----------- ----------------- node0 - - Not attempted yet node1 aggr1 node0 Done aggr2 node0 In progress aggr3 node0 Not attempted yet 4 entries were displayed.
