storage iscsi-initiator connect
Connect to an iSCSI target
The storage iscsi-initiator connect command connects a node to the specified target. This command is only supported on high-availability shared-nothing virtualized platforms.
-node {<nodename>|local} - Node
Specifies the name of the Data ONTAP node to which the iSCSI target will be connected.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}] - Target Type
Selects targets with the specified target type.
-label <text> - User Defined Identifier
Specifies the label of the target to connect to.
The following example adds and connects to an iSCSI target from the specified node.
cluster1::*> storage iscsi-initiator connect -node node1
             -label target1
