security login banner show
Display the login banner message
The security login banner show
command displays the login banner.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Selects login banners that match the specified value. Use the name of the admin Vserver to specify the cluster-level login banner.
[-message <text>]
- Login Banner Message-
Selects login banners that match the specified value. By default, this command will not display unconfigured, or empty, login banners. To display all banners, specify `-message
The following shows sample output from this command:
cluster1::> security login banner show Message ----------------------------------------------------------------------------- Authorized users only! cluster1::>
