vserver peer permission show
Display Vserver peer permissions
The vserver peer permission show command displays the following information about Vserver peer permissions:
  • Peer cluster name
  • Local Vserver name
  • Applications
{ [-fields <fieldname>,…​]
| [-instance ] }
[-peer-cluster <text>] - Peer Cluster Name
If this parameter is specified, the command displays permissions that have the specified peer cluster name.
[-vserver <text>] - Vserver Name
If this parameter is specified, the command displays permissions that match the specified local Vserver.
[-applications {snapmirror|flexcache}] - Peering Applications
If this parameter is specified, the command displays permissions that have the specified applications.
The following examples illustrate how to display Vserver peer permissions:
cluster1::> vserver peer permission show
Peer Cluster     Vserver         Applications
cluster2         "*"             snapmirror
cluster3         vs1             snapmirror
2 entries were displayed.
