vserver peer permission show
Display Vserver peer permissions
The vserver peer permission show command displays the following information about Vserver peer permissions:
Peer cluster name
Local Vserver name
Applications
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-peer-cluster <text>]- Peer Cluster Name-
If this parameter is specified, the command displays permissions that have the specified peer cluster name.
[-vserver <text>]- Vserver Name-
If this parameter is specified, the command displays permissions that match the specified local Vserver.
[-applications <snapmirror>,…]- Peering Applications-
If this parameter is specified, the command displays permissions that have the specified applications.
The following examples illustrate how to display Vserver peer permissions:
cluster1::> vserver peer permission show Peer Cluster Vserver Applications ---------------- --------------- ----------------- cluster2 "*" snapmirror cluster3 vs1 snapmirror 2 entries were displayed.
