system node virtual-machine hypervisor modify-credentials
Modify hypervisor IP address and its credentials
The system node virtual-machine hypervisor modify-credentials
command is used to set the IP address
of the hypervisor on which the node is running or vSphere credentials (i.e. -new-username
or -new-password
-node {<nodename>|local}
- Node-
Name of the Data ONTAP node running in a virtual machine. It is a required field and the node must exist in the cluster.
[-new-server <text>]
- New Hypervisor IP Address-
New vSphere server controlling this virtual machine. It can be either an IP address or (if name resolution is enabled) a hostname.
[-new-username <text>]
- New Hypervisor Username-
New vSphere username for the
-new-server
specified above. [-new-password <text>]
- New Hypervisor Password-
New vSphere password for the
-new-server
specified above.
The following example sets the IP address and the credentials of the vSphere server on which the node is running.
cluster1::> system node virtual-machine hypervisor modify-credentials -node node1 -new-server 192.168.0.1 -new-username admin -new-password pass123
